i don't arrive to re-install my 3CX. It send me this message
bahkamena
System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 28P01: password authentication failed for user "phonesystem" ---> Npgsql.PostgresException (0x80004005): 28P01: password authentication failed for user "phonesystem" at Npgsql.NpgsqlConnector.
Hi @bahkamena,
Can you explain what you're trying to do? Did you uninstall 3CX and you're now trying to install again on top?
Yes, i uninstalled it and now i am trying to install but i don't arrive
Hi @bahkamena,
Whenever a new package that depends on other packages is installed on the system, the package dependencies will be installed too.
When the package is removed, the dependencies will stay on the system because I am assuming you removed 3CX with command:
apt-get remove 3cxpbx
(without --purge)
The solution to your problem is to remove everything and start from the beginning.
First uninstall 3CX again:
Code:
apt-get remove 3cxpbx --purge
Then also try the following command to also uninstall postgres
Code:
apt-get remove postgres --purge
After doing this, try starting the 3CX installation from the beginning.
If this fails, I suggest scrapping the installation all together and re-deploying it from the 3CX ISO.
zipman
