i have problem in my 3cx phone system
abduljalilalnemer
Device 0565582765 dialed on (AnyLine@Generic VoIP Provider) had no available outgoing trunk(s) for Call(from "abduljalil alnemer"<sip:[email protected]>;tag=a5ecc8735a7cfe8o0 to 0565582765)
i got this error suddenly every thing is stopped can any one help me
Did you defined the outgoing roules?
Did it work before with no changes on 3cx site?
Any other calls to the same time? Did you defined any other outgoing rules?
Have you checked if the SipTrunk itself is up and running and no issues with the provider?
Since there have been no changes made and it happend suddenly i would look there first instead of checking the programming that has not beel altered according to yourself.
In the trunk settings, how many concurrent calls have you allowed?
The trunk shows as registered?
As mentioned here, is your trunk up? Are you using an IP based or an authentication based provider? Is your provider registered?
Reactions: JosIPVG
You don't mention if you can receive incoming calls....
Senergia
