- Joined
- Feb 10, 2015
- Messages
- 8
- Reaction score
- 0
elastix-2.5.0-1
If Incoming number begin with +, cold'not download or listen recording in CDR
PBX->Calls Recordings->Monitoring List
Example in my CDR Incoming number:
+380996100000
Maybe error in /var/www/html/modules/monitoring/index.php ???
UPDATE:
i'm found in /var/www/html/modules/monitoring/libs/paloSantoMonitoring.class.php
AND MY CHANGE:
WORK IS FINE ))))
My config:
+380996100000
UPDATE:
Code:
function getAudioByUniqueId($id, $namefile = NULL)
$query = 'SELECT recordingfile FROM cdr WHERE uniqueid = ?';
$parame = array($id);
if (!is_null($namefile)) {
$query .= ' AND recordingfile LIKE ?';
$parame[] = '%'.$namefile.'%';
$result=$this->_DB->getFirstRowQuery($query, true, $parame);
if($result==FALSE){
$this->errMsg = $this->_DB->errMsg;
return null;
return $result;
AND MY CHANGE:
Code:
$namefile = ereg_replace("+", "",$namefile); //I'm ADD THIS STRING
if($result==FALSE){
return null;
return $result;
WORK IS FINE ))))
My config:
Code:
Kernel
Linux(i386)-2.6.18-406.el5
Elastix
elastix-2.5.0-1
elastix-a2billing-1.9.4-7
elastix-a2billing-callback_daemon-1.9.4-7
elastix-addons-2.5.0-3
elastix-agenda-2.5.0-1
elastix-asterisk-sounds-1.2.3-1
elastix-email_admin-2.5.0-1
elastix-endpointconfig2-2.5.0-1
elastix-extras-2.5.0-1
elastix-fax-2.5.0-1
elastix-firstboot-2.5.0-1
elastix-framework-2.5.0-2
elastix-im-2.5.0-1
elastix-my_extension-2.5.0-1
elastix-pbx-2.5.0-1
elastix-portknock-0.0.1-0
elastix-reports-2.5.0-1
elastix-security-2.5.0-1
elastix-sugarcrm-addon-5.2.0l-9
elastix-system-2.5.0-1
RoundCubeMail
RoundCubeMail-0.3.1-12
Mail
postfix-2.3.3-7.el5
cyrus-imapd-2.3.7-16.el5_11
IM
openfire-3.7.1-1
FreePBX
freePBX-2.11.0-19
Asterisk
asterisk-11.17.1-1
asterisk-perl-1.03-0
asterisk-addons-11.17.1-1
FAX
hylafax-4.3.11-1rhel5
iaxmodem-1.2.0-2
DRIVERS
dahdi-2.10.0.1-3
rhino-0.99.6-4.b4
wanpipe-util-7.0.12-3
