Import Contacts
Simone Rota
Forum User
I'm receiving the message:
"You can ignore bad data by setting BadDataFound to null."
I've more than 10.000 record.
Is it a question of limits?
What's the limit?
Simo
I believe you can only import 500 at a time
One thing to note, if you have physical handsets you may find there will not be able to couple with this amount of phone book entries. Most phones only have a small amount of memory that can hold contacts
Note sure about windows 3cx, mobile app and webclients
tohoken1
