Solved Import user from AD/CSV file
okba60
I am currently experiencing problems to make an AD import, indeed all my users do not appear (import and then import AD) by clicking on search, I have many users who display but not all.
I miss a lot in those posted, there's a limitation? I have more than 1000 AD users ...
Also via CSV, I took the .csv example given on the site.
I opened via excel (by doing semicolon delimited convert)
When I try to import my CSV, error message:
"Wrong CSV file, the necessary columns do not exist"
Which fields are required? I would like to fill only the columns name, first names, extensions and emails.
Here is attached my csv, what I messed up?
Knowing that my file is in .csv (saved via excel csv delimited by semicolon)
Thank you
Open our CSV in NotePad++ and then open the one you made in Excel in NotePad++
I think you will see a difference in what Excel does, injecting more characters like " "
yes, an AD just returns on request the first 1000 (or even 500) users.
Now ad-users are also an issue as this also contains "computers" (I don't know why an AD property user is set for a PC until today). You can sync to Azure AD and we read them all from there via API.
I do it a lot of times, i don't see a difference in excel and notepad++
Nothing like " "
How you a tutorial with ad azure?
I found the problem
Can close topic
What did you found? can you share your fix? would be nice for those with similar problem
You have to add to the csv this fills completed:
authid
authpassword
pin
devo.it
