Importing Call Cost table
per.eriksson_1
I finally got the call cost table from my provider: 90.000 entries!
With the knowledge that there is no easy way to delete the whole table if things go sideways.... I am very reluctant to import this massive amount of records.
If there was a "reset to default" button for the table it would have made my life easier instead of 90.000 mouse clicks on the X on each and every entry.....
How do you others do to get reliable call cost output from the CDR files?
Mr_IT
