Impossible to add a new phone
Arnaud6850
SOHO User
Hello all.
I've the 3CX Free and 2 users and 1 phone.
I want to add a second phone (for the second user)
It's impossible to add. Automatically (with Mac address) ou manually.
It's greyed.
Do you have any idea about this problem ?
Already tried with FF / Edge or Chrome.
Thanks,
You need to connect the phones over an sbc or use an router phone.
Hello bitn2 and thanks for your reply.
I've 2 phones already with STUN and the worked. The new one don't work.
So it's the new polotics of 3CX to disable them ? So I'll change for another PBX. I won't install an SBC just for a network with 1 phone !
Have a nice day,
Best regards,
If your pbx is not local to your phones you always need an sbc or routerphone.
Since When ? Because I've already 2 phones who work like a charm with cloud Free 3CX v20
Since v20. On v18 you could use stun, but for safety reasons this is not possible anymore. You can install an sbc anywhere you want, windows, linux, raspberry or use an routerphone with integrated sbc.
I jnow I can install SBC everywhere I want. Thanks for this.
Sorry but my 3CX is Version 20.0 Update 5 (Build 527) and STUN phones worked
Not anymore as you see... You need an sbc to use the free cloud pbx. If you host by yourself you can use stun at your own risk, it is not supported anymore. Why is it such a problem to use an sbc?
Not anymore, so I think it's since the last release.
The problem is that If I have only 1 phone for a client who use a FREE pbx, it's very boring to install and buy an SBC for this. In this case, I just install a PSTN phone and "voilà".
If I have 5 or 10 phones, it's different of course (and this time, I don't take the free 3CX, but the pro)
Thanks for your help and have a nice day.
Best regards,
I would go with stuff that could break at any time.... Its not really a problem to use an routerphone or an sbc that you can install anywhere...
For a litte non-profit company, it's a cost. 3 people in 3 different buildings means 3 phones (we have them) and 3 sbc. No server there, so we need 3 physicall SBC with the cost of a raspberry : 3 * 100 = 300 $. So I search another solution like install e FreePBX instead of 3CX.
Incorrect..
assume you all have PCs at this site?
Install the SBC once on a desktop and set the phones to use this.
Reactions: bitn2
A Raspberry is way cheaper, but anyway you can install it also on an pc or any other device you have. The easiest way is to use an routerphone. But anyway you are free to try freepbx or any other stuff und be sure you will come back.
No pc on the site only laptops. So no laptops, no phone this day ! It's very frustating. a simple thing becomes so complicated!
I don't think I will come back. With the v18 yes; With the v20, no !
Have a nice day bitn2 ans thanks for your help.
You too and bye :p
Damn unfortunately 3CX isnt a charity so you're gonna have to give something to get a little.
Reactions: bitn2 and GregG_3CX
LeeonLau
