Improved AI Call Summaries in V20 Update 10
LeonidasG_3CX
Product Manager
Staff member
Update 10 makes AI call summaries more useful by adding notes and action items.​
A call summary should tell you more than just what was said. With V20 Update 10, 3CX AI call summaries now include Notes and Action Items alongside the existing summary. This gives support, sales and other teams a clearer view of the call outcome, important...
Great News Thanks
I'm on Update 10 RC 2 and using the 3CX AI server on a Mac Mini. Call transcriptions are working fine, but the summaries don't show up. Do these show in the normal recordings area? Do I need to manually enable summaries?
When you receive an email with the transcription, it does not contain them? Were any changes done to the summary prompt while testing at some point?
In general, if you go to the recordings view, the call summary pops up when you click the "wave icon":
Hmm, I don't get emails with transcriptions from calls. Only for voicemails.
No changes made to the summary prompt, I've reset it for good measure.
If I go to the recordings view, the transcript is available, but the wave icon and summary arent. If I press the 3 dots, summary is greyed out
@lewiswil , I'll ask you for some extra info so we can look into this in some detail.
Hello @lewiswil ,
After getting some more info, you have probably "inherited" something that was actually fixed in RC2.
In any case, do the following and see if it's fixed:
Click on Edit, type in some random text, click OK then Save.
Come back in, click on Edit, choose Reset to 3CX Default, click OK then Save.
Make a call and see if the summary for it appears.
Let us know if this works for you.
AshokUmmiti
