Solved Incom ICW-1000G
mtech1
I appreciate these are not on the supported list. BUT.... Does anyone have any experiences provisioning the Incom ICW-1000G WiFi Phones? I have started to put together a .ini file for them but I am having issues getting the specific file to deploy
Spectralink WiFi phones I do, and writing a 3CX supported provisioning template was a bit of a pain so I simply used the standard ones provided by the vendor and used a 3rd party provisioning server.
Reactions: mtech1
After some further troubleshooting I found 2 very simple issues!
1) The bar code on the box was missing the leading 0 on the MAC address so when I was scanning the MAC addresses for the file names they were wrong.
2) The file name is case sensitive, and must be all lower case.
(its always something simple in the end!!)
Glad to see the issue has been resolved and thank you for updating the thread with your solution
Bluebox Global
