Incoming call rejects by all Apps (iOS, Android, MAC, Windows)
Evgeniy L.
Hello everyone
Incoming call drops an attempt to ring to app and redirect to voice mail as rejected call. Iv no voicemail enabled, then call simply drops as busy.
Reproduces for Android, iOS, MacOS and windows clients.
Outgoing calls from apps works fine.
Desk phones (cisco and Yealink) receives calls normally only in case extension have no App provisioned.
issue started with 3cx 16.0.4 on Debian 9 (it's better to say spotted, due to nobody used apps before COVID-19 remote working case accured)
Upgrade to 16.0.5.611 changed nothing.
Here is verbose log for the case:
04/28/2020 4:37:28 PM - SendMsg from "Test User"<sip:[email protected]:5060>;tag=7ca1e071 to <sip:1119@FQDN_address_here:5060>;tag=c0578842
04/28/2020 4:37:28 PM - L:157.3[VMail:6666] got Provisional Recv 180/INVITE from 127.0.0.1:5483 tid=236f5d0c7edd8849 Call-ID=TpveX_q3wqAtEFDH7iZodg..:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-524287-1---236f5d0c7edd8849;rport=5060
Contact: <sip:[email protected]:5483;rinstance=8b1b5e2a1e949b8b>
To: <sip:1119@FQDN_address_here:5060>;tag=c0578842
From: "Test User"<sip:[email protected]:5060>;tag=7ca1e071
Call-ID: TpveX_q3wqAtEFDH7iZodg..
CSeq: 1 INVITE
User-Agent: 3CX Voice Mail Menu
Content-Length: 0
04/28/2020 4:37:28 PM - Provisional(180) from <sip:1119@FQDN_address_here:5060>;tag=c0578842 to "Test User"<sip:[email protected]:5060>;tag=7ca1e071
04/28/2020 4:37:28 PM - [CM505001]: Endpoint VMail:6666: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:[email protected]:5060]
04/28/2020 4:37:28 PM - [CM503002]: Call(C:157): Alerting VMail:6666 by contact <sip:[email protected]:5483/UDP>
04/28/2020 4:37:28 PM - Answer from <sip:1119@FQDN_address_here:5060>;tag=c0578842 to "Test User"<sip:[email protected]:5060>;tag=7ca1e071
04/28/2020 4:37:28 PM - Leg L:157.2[Extn:1119] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2020 4:37:28 PM - L:157.2[Extn:1119] got Terminated Recv 487/INVITE from 127.0.0.1:5483 tid=c1c66709b08afb02 Call-ID=yvUcutwvczqxdHhpuNAE2w..:
SIP/2.0 487 Request Terminated
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-524287-1---c1c66709b08afb02;rport=5060
To: <sip:[email protected]>;tag=5947016d
From: "Test User"<sip:[email protected]:5060>;tag=1fb05e2c
Call-ID: yvUcutwvczqxdHhpuNAE2w..
CSeq: 1 INVITE
User-Agent: 3CX Mobile Client
Content-Length: 0
04/28/2020 4:37:28 PM - Terminated from <sip:[email protected]>;tag=5947016d to "Test User"<sip:[email protected]:5060>;tag=1fb05e2c; reason: Error
04/28/2020 4:37:28 PM - L:157.2[Extn:1119] got Failure: Failure Recv 487/INVITE from 127.0.0.1:5483 tid=c1c66709b08afb02 Call-ID=yvUcutwvczqxdHhpuNAE2w..:
CSeq: 1 INVITE
Content-Length: 0
04/28/2020 4:37:28 PM - [CM503003]: Call(C:157): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2020 4:37:28 PM - Session 102085 has failed in leg L:157.2[Extn:1119] ; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/28/2020 4:37:28 PM - Failure from <sip:[email protected]>;tag=5947016d to "Test User"<sip:[email protected]:5060>;tag=1fb05e2c
04/28/2020 4:37:28 PM - [CM503025]: Call(C:157): Calling T:VMail:6666@[Dev:sip:[email protected]:5483;rinstance=8b1b5e2a1e949b8b] for L:157.1[Extn:1118]
04/28/2020 4:37:28 PM - Route to L:157.3[VMail:6666] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=236f5d0c7edd8849 Call-ID=TpveX_q3wqAtEFDH7iZodg..:
INVITE sip:[email protected]:5483;rinstance=8b1b5e2a1e949b8b SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---236f5d0c7edd8849;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
Content-Length: 421
v=0
o=3cxPS 20638096756310016 14825550346452993 IN IP4 127.0.0.1
s=3cxPS Audio call
c=IN IP4 127.0.0.1
t=0 0
m=audio 7882 RTP/AVP 0 8 9 3 18 112 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:112 opus/48000/2
a=fmtp:112 maxplaybackrate=16000;sprop-maxcapturerate=16000
a=rtpmap:101 telephone-event/8000
a=sendrecv
Dear John,
As I mentioned above:
3CX is 16.0.5.611
Server OS: Debian 9
On-premise dedicated server.
issue reproduces on ext to ext calls (and on incoming calls from PSTNs too)
Issue was reproduced with newly provisioned extensions and logs collected for initial post.
Android App tested 16.2.0.93
iOS App was latst available from AppStore today (sorry, have no iPhone near by)
3cx for MacOS 16.0.1.0
Web client of 16.0.5.611
Apps provisioned with tunnel over 5090 port.
We have Bridge trunks working fine in both directions over same 5090 port, so no firewall issues there expected.
Also outgoing calls from Apps going fine to other branch ot to other extensions with desk phones only.
I hope this helps.
PS: sometmes app rings once and rejects call to voicemail, sometimes no any rings on app, just a notification about missed call comes immediately after call rejected to voicemail.
Can you also try with a new extension please as I described above?
3CX is16.0.612
Server Windows 10
We can confirm this problem when app and yealink desk phone are assigned on same extension and app has been provisioned on android device.
The call is able to be answered on android device and does not ring desk phone.
We get Cause: 488 Not Acceptable Here/INVITE
Created test extension as requested with no desk phone and provisioned same android device with test extension.
We can call in and the desk phone is accessible through Digital assistant but DID fails.
We did try partialy availble here but that had no affect:
https://www.3cx.com/docs/android-app-faq/
@illcsales I think your case is different, the inverse of the above. You should start a separate thread.
Dear John,
The test done and log provided with newly created extensions (you can notice "Test User " mentioned in logs)
I've created few more extensions - results and logs text are the same.
Thanks Evgeniy, can you also now check with the Webclient now?
This should tell us where to look next.
3K8iMGWviZ
