Incoming call showing ANI with Ring group name
sam kumar
Hi please can you help removing ring group name from incoming call display
I have setup a ring group to ring all for support team added 3 ext in it when someone calling Inbond call its displaying their ANI with Ring Group name, it should be only ANI display.
Hi.
If you navigate to the Advanced (in the Management console )>> Contacts
you can select the option Do not add , so that it wont prepend/append the name of your inbound name/ring group
can't see such option in Management console Advanced........Contacts
There is only add contact details not like add group, Queue or DID/DDI Names to Caller ID
Can you please confirm that you don't have the options as per below screenshot?
Issue is resolved.
Reactions: TheodorosG_3CX
megalmazan
