Solved incoming call
KhaledQuenawy
why all incoming call name is anonymos ... how to show the caller number
Look under Contacts - Options in the PBX.
There are settings for adding caller ids here.
Failing that I would Wireshark and see if the CLID is coming from the provider or not.
adding contact not solution ... i just need to show the number not the name
Well this should be as standard, who is the provider? I use Twilio and they do this without any setting changes being required.
Ok i call my provider ... they told me that this is optional services and we are not register .. thank you all
GP Concepts
