- Joined
- Jan 9, 2014
- Messages
- 5,077
- Reaction score
- 1,096
Hi;
strange situation tonight, i've a Cloud amazon lightsail PBX running 3CX latest version.
This pbx has a working SIP trunk from Openip and receive also incoming calls from a OVH SIP number , in OVH manager this line is permanently forwarded to Openip sip trunk number.
This is working like this, waiting porting time to eliminate OVH at the end.
For now, when i call OVH number, i hear ring back tone but nothing is visible in "Number of calls in use" not either in "activity log" (absolutely nothing traced) when i hang up that's the weird part, call history increase 3 calls in once with exact same " from " number which is mine so it seems OVH send good number to 3CX via Openip trunk and "to" field is mobile line on which inbound rule need to forward when OOH (that's good too).
On end mobile line nothing rings.
If i call directly on Openip number, everything is ok, mobile receive call and audio both ways.
I re registred openip trunk, rebooted 3CX and do new tests with no behavior change. I suspect OVH forwarding, but for now i have no access to this settings, customer only has.
If I force OH with *641 , then incoming OVH calls are working and forward to external number works. Might be a restriction on OVH side? or what can change on 3CX side when in OOH?
what do you think about this ?
