Incoming calls - intermittently hearing voicemail
Alphabetic
3CX MVP
Good morning
I've just stuck in a new install for a customer and they're telling me that randomly they'll pick up a call and they'll hear the end of the voicemail message followed by the caller leaving a voicemail. When this happens, the caller cannot hear them.
Not sure how to diagnose this one so any suggestions are appreciated.
3CX Pro 18.0
Hosted with SBC Pi
7 x Yealink T42S - 66.86.0.5
Default templates
Supported BT WSIPT provider
Pi is v 18.0.30
Hi @kieferschild,
Does this happen on all extensions / devices or only specific ones? Is it reproducible, as in will it happen consistently each time they follow the same course of action? Where is the PBX hosted?
Hi @kieferschild,
Hi Vasilis
3CX is hosted in OVH.
They are unable to reproduce it.
Calls come into the IVR then to a Q.
It has not happened to them today thus far.
Waiting to hear back if it's one phone or several.
Okay @kieferschild, when you update the thread with more info I'll take a look. Glad it's not happened today so far.
Hi @kieferschild,
How often would they say it happens? Does this occur regularly enough for you to schedule a packet capture that you can leave running until it happens again?
Unfortunately not.
If I get another occurrence of the problem then I will ask the customer to make test calls in until they reproduce the problem. But, I have changed the ring time today.
Reactions: VasilisV_3CX
Sure thing, keep me posted if it happens again, will leave the thread open.
I've factory reset a few of the problematic phones and apparently "its fixed" so time will tell.
Great to hear, well done. I'll close this, go ahead and open a new thread if they provide any more feedback regarding any issues.
WagnerFT
