- Joined
- Mar 15, 2013
- Messages
- 3
- Reaction score
- 1
Dear Colleagues,
We started experiencing this issue recently. Incoming calls to any ring group fail and the call goes to Destination if no answer. The ring group works if called locally from another extension.
The following is in the regular logs:
So far I tried everything I found here but no luck.
Your help is highly appreciated.
Ara
| 04/25/2022 12:34:48 PM - [CM503003]: Call(C:354): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483 |
| 04/25/2022 12:34:48 PM - [CM503003]: Call(C:354): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.202:5060 |
| 04/25/2022 12:34:48 PM - [CM503003]: Call(C:354): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.239:5060 |
| 04/25/2022 12:34:48 PM - [CM503003]: Call(C:354): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.204:5060 |
| 04/25/2022 12:34:48 PM - [CM503003]: Call(C:354): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.201:5060 |
Ara
