Solved Incoming Fax Sometimes Page Cut Off
cchsbrad
We are having an issue where sometimes the incoming fax PDF is cut off (see attached). Any ideas?
Thanks!
Using version 16.0.8.9 and Fax Server with the beta Enable G.711 to T.38 Fallback on. Using Skyetel SIP trunk with Inbound Rule route to Sent fax to xxx (fax server extension). I have only received a half-dozen faxes so far, but half of them have a page or two cut off. Would any other details be useful?
So g.711 to t.38 fallback should be off as Skyetel does support T.38. I would start there.
Just turned it off and will see how it goes. Thanks!
We've only received 3 faxes since disabling the feature, but so far so good. Thanks!
Reactions: VasilisV_3CX
Excellent @cchsbrad! I'll mark the issue solved for now. If you need any help with it going forward, feel free to open a new thread!
devo.it
