Incoming SIP URI address
hernanp
SOHO User
Is there a way to receive calls into a 3CX via a sip uri? I thought something like DID@FDQN, but I don't know if this is doable.
This site suggest configuring it in Settings-Network, but I don't have Network there. https://www.3cx.com/blog/voip-howto/direct-sip/
Thanks!
Unfortunately not as this requires the use of a SIP ID and an option that needs to be enabled, found under the network tab of the management console under the settings for which there is no option to access with 3CX Hosted instances.
Additionally, SIP URI Dialing is only possible direct to IP phones it can not be done either through SIP trunks or to the 3CX Apps, Webclients, etc...
mazet
