Solved Incorrect license key supplied
aceltic
yesterday an error message came to my mailbox. It is also shown at the event registry.
It says:
Incorrect license key supplied​
The FQDN you configured at installation time is not linked to the license key which is currently activated. As a result, video conferences cannot work. Activate the license used at FQDN creation time or re-install and use your new license key and link it to a new FQDN.​
My License is bound to the FQDN XXXXXXX.3cx.es and because of that, the webmeeting FQDN is XXXXXXX-es.3cx.net
PBX version is 16.0.493
Why is this happening? As the message says... Webmeeting is not working anymore.
Thank you in advance.
Restart your services. 3CX was doing some upgrades/maintenance to the webmeeting infrastructure that caused this message. Per them, it shouldn't actually have caused a problem but if it does, reboot.
https://status.3cx.net
Reactions: aceltic
Perfect, it worked. Thank you!
intoxtech
