Increase 3cx size
Ahmed Mohamed
i need to increase 3cx instance size without damage the current 3cx just increase the space
can you send me instructions its Debian and on cloud as a VPS on Digtalocean
It's most surely an asking for DO not for 3CX ;)
You would need to make your hard drive size bigger then re-run the 3CX ISO installer where you can expand the partition from this wizard.
so it will be re install correct ?
It wont reinstall, the option is purely to expend the partition if memory serves. Otherwise, you could download a gparted ISO and expand the partition that way too.
in DO when you pick a new Droplet Size you have the option to resize the instance also in this moment (droplet needs to be powered off)...
fransisco
