Individual office hours
Aitie
I'm setting up a 3CX environment where not every user is working the same hours/days but they are in a ring group.
They put themselves as away for the moment if they aren't available.
Is there an option in 3CX where i can set office hours for individual extensions?
Kind regards,
Robin
Kind regards,
Robin
Yes you can but it's only used for the "Auto-switch status" feature. If they already use statuses to make them "offline/away", then you don't need to modify the user's hours.
Hi @Aitie,
You can set up office hours for each user individually from their WebClient/Desktop App >> Settings >> Status Scheduler >> Enable 'Automatically switch status to available during office hours' and the option to set up specific hours for each user will appear. The users will be switched to Available during Office hours and to Do not Disturb during Out of Office Hours.
In case you want to make changes to other extensions office hours without having to login to each Web Client individually, you can create a new extension or an already existing extension, and give it "Manage all extension"/"Manage extensions in groups you are part of(will be able to manage other extensions of the same group only)" and the "System Administration" rights that will enable the Admin section in the WebClient/Desktop App of that extension and will be able to manage the 'Status Scheduler' configuration of the other users.
With this setup, you will be able to manage the extensions the Status Scheduler configuration and set office hours of other extensions from the WebClient/Desktop App >> Admin(bottom left) >> Users, of the extension's that the abovementioned rights were given.
The 'Admin' section in the WebClient/DesktopApp has as a prerequisite that the PBX is on the latest version(18.0.5.418).
Thanks for the answers. that's what i needed.
Would it be possible to have opening hours for an call queue / ring group?
Hello @Aitie
Queues and Ring Groups do not have this option. Specific hours can be configured for Inbound Rules but alternatively, you can also create a "dummy extension" with forwarding rule exceptions that point to the Queue or Ring Group for only specific hours and route your calls to that "dummy extension" instead.
VR46
