Solved install-instance-manager returned error code 255
bvieck
Two new Debian iso installs with restore from backup of previous Windows 3CX servers and both get the same error message when trying to enable the Instance Manager.
Tried rebooting both servers and still get the error message. Everything else is running fine.
I have a similar situation, servers are all fine but cannot get instance manager to enable on them with error code 255
@bvieck You can try this if you have not reached out to support already, see below:
run the following command as root, once it is complete try and enable the instance manager again it should work this time. (it did for me)
Bash:
wget -O - https://downloads.3cx.com/downloads/misc/debianpatches/9/16/0/5/20200619-os-update.sh | bash
I had the same issue and this command has fixed it. thanks @BJS
Bash:
Thank You! That worked.
Bash:
BJS, Thanks. Worked for me.
EMMEPICASA
