Solved Install Outlook plugin on standard edition
Severin Meyer
As I understand, it should be possible to install the 3CX-Outlook plugin on a standard license by installing:
http://downloads.3cx.com/downloads/3CXPlugins15.exe
Unfortunately this will not install the vsto files required for Outlook.
On a pro license the files are downloaded the first time the client is starting, when the extension has enabled integration.
So what would be the official way to install the 3CX-Outlook plugin on a standard license?
Yes this is where I get the download link.
But activating the Integration for an extension is not possible in Standard edition (free).
As of today, the outlook plugin has been installed correctly on the client magically.
So my problem is solved.
Reactions: Marios Neophytou
neshima
