Installing 3CX on Debian 11 in VPS
Deepak | Aastitva.com
I had installed 3CX on Debian before using command line from root of VPS Debian server.
I used to get the repository from
echo "deb http://downloads-global.3cx.com/downloads/debian stretch main" | sudo tee /etc/apt/sources.list.d/3cxpbx.list
Is the link not working?
Regards,
Abhijit
Don't use Debian 11. You have "stretch main" in your repo list. Stretch is Debian 9.
From your 3CX portal, you can download a Debian 10 ISO with the 3CX repo already added to it.
I believe 3cx is working on the nextmajor release of 3CX to be running on Debian 12 Bookworm.
What Nathan said, but unless I'm mistaken 3CX does not support or facilitate installing 3CX outside of their ISO, anymore.
Got the point. The problem is to upload ISO to VPS. I am using Putty to login and for command line. Downloading repository online is easier option while working with VPS that doesn't give UI.
If you're on a supported platform (Google Cloud, Azure, Amazon, DigitalOcean) you can deploy it as a new server, or otherwise you have to use a host who can allow uploading an ISO from which you boot a new VM. It's not going to work on an existing VPS, I don't think that's possible anymore.
Thank you for your update.
Let me talk to the hosting provider.
Who is the cloud provider?
postmaster@studiolegaleda
