Instant listing of all incoming calls
oguzhan51511
I'm using version 12. Is there a service where I can receive incoming calls as socket or webhook?
I was able to receive CDR recordings from port 33555. But when the call is closed, information falls. I want to be triggered when the phone is ringing. I'll show you who's calling.
You could build a 3CX Phone for Windows plugin.
I'm sure you have very good reasons for remaining on 3CX version 12. However, you know you are at risk of your 3CX not being able to register your license key if you make any changes to your 3CX server (like changing your network interface card), or moving to a new VM, etc.
You really, really, really need to move to V16. You don't want your 3CX server dictating when you perform an upgrade because it can't register. It is far better that you plan for, and control when you perform the upgrade. You don't want to be trying to upgrade from 12, 14, 15.5, 16 right in the middle of the week because your server won't register. This is a well-documented limitation of V12. You are at significant risk.
postmaster@studiolegaleda
