integration with called number option
Renehallo
Titanium Partner
We want to make a integration with a customized CRM (webbased). Therefore we need the intergration option in the 3CX webclient to send the called number. At this moment only
  • %CallerNumber% which will contain the incoming caller id.
  • %CallerDisplayName% which will contain incoming Display names
are supported.
Is it possible to add the funtionality to use the sting for called number parameter?
Reactions: [email protected]
Unfortunately this is not possible at the moment.
postmaster@studiolegaleda
