- Joined
- Mar 5, 2025
- Messages
- 2
- Reaction score
- 1
I have some difficulties to understand how to configure the 3CX with a custom CRM. In my case with efficy Enterprise.
Most of explanations pointing to the guideline: https://www.3cx.com/docs/crm-integration
While following the process of 3CX CRM Template Wizard there is no way to integrate custom headers. Most posts in forum mentioning the xml file.
I understood that this one is generated by 3CX CRM Template Wizard. Do you have a proper documentation on XML tags to use and their descriptions ?
Efficy Enterprise CRM do not have a standard REST API. It has an JSON RPC API which is different from REST API's.
Ex of request body:
Response body:
The authentication is made through custom headers. There is also a cookie session that is return on first call and it is recommended to reuse the cookie session to not open each time a new one.
More details: https://help.efficy.io/edn/projectguides/remote_apis
How could I implement it to the template wizard or XML ?
If you have a proper documentation on defining the XML tags I think it would be easier than going through the Template Wizard.
Kr,
Hamid
Ex of request body:
JavaScript:
"@name": "consult",
"entity": "Cont",
"key": 286,
"@func": [
{"@name": "master", "tableview":0, "includeblobcontent": true}
Response body:
JavaScript:
"@name": "consult",
"entity": "Cont",
"key": 286,
"@func": [
"@name": "master",
"tableview": 0,
"includeblobcontent": true,
"#result": {
"#class": "dataset",
"#data": [
"K_CONTACT": 286,
"NAME": "Doe",
"PICTURE": "..."
"#handled": true
"consulthandle": "24",
"#handled": true
Kr,
Hamid
