Integration
DylanB
Platinum Partner
Hello All
I hope all is well!
I am looking into Integrating our 3cx system with the Jobnumbis CRM system and was wondering if anyone here has done this before, if so could you provide some assistance with where I can find the CRM Config file for Jobnumbis.
Also a question.
If we where to change CRM systems would I be able to remove or Undo the integration that has been done and integrate with a new CRM later on?
Your feedback is Greatly appreciated!
Regards.
From what I could find, there's an API for Jobnumbis, so an integration is definitely possible. I did a quick check of their API docs and it seems it would be relatively easy to implement.
As for your second question, yes you can always change the CRM integration in the 3CX settings.
Reactions: edossantos
as3ad19911991
