Inter digit timeout 3CX
Leonardo Santana
Forum User
Is there any configuration that we can low the interdigit timeout for the clients?
Regards
Can you clarify? Interdigit timing is normally used on devices that don't require you press a send (dial) key after dialling.
Hi @Leonardo Santana,
As @leejor asks, what is your use case? What device are you wanting to change the inter digit timer for?
If you mean for the Web Client, Windows Client, Mobile Client and Desktop App, each will require you to hit the call button.
laranicole.lucus
