Intercom x7a
networkrevolt
hello,
dose anyone know how if there is a way to make intercom to not ring but just come over the phone when a user intercoms them? I have paging setup as *77-ext.
If you try to make an intercom call without having the correct rights, the destination will just ring.
So make sure your extension has the right "Can intercom" enabled, then dial star + paging dial code + extension.
PS: Also make sure your selected dial code does not conflict with some other dial code in case the above didn't work.
infinititravels
