internal port range
UncleArt
Hi Guys,
In regards to internal port range mentioned in your recent SP6 release notes
7000-8499 UDP
Could you please confirm in which case you would use/open them. We've never touched these ports in past
If you don't restrict internal traffic, then you don't need to worry about these ports.
Reactions: craigreilly
Hello @UncleArt
If you do not limit internal traffic then these ports won't affect you and you do not need to adjust anything. If internal traffic is limited however then you should adjust for the new ports as you may experience audio issues if some of the ports are blocked.
Zexus
