- Joined
- Sep 10, 2020
- Messages
- 8
- Reaction score
- 0
Hi 3CX community,
Hoping to get some direction as I have run out of troubleshooting ideas. We experience these problems since the 3CX update in late august. Prior to that everything was working.
currently:
-unable to make phone calls from IOS and android 3cx App
-App shows as "connecting..." in the top right corner of the app
-We receive incoming calls on IOS and Android phones but cannot pick up the call.
-no problems with windows client or chrome app. All works seamlessly in the office and externally.
-Tried on several models of iphones, with IOS 14.0.1
-Tested on internal wifi as well and LTE from home broadband
-Ran firewall tested on 3CX - everything passed
-Double checked firewall all settings based on the following links: https://www.3cx.com/docs/manual/firewall-router-configuration/, https://www.3cx.com/docs/sonicwall-firewall-configuration/
-Restart of 3CX server
-uninstalled antivirus
-disable windows firewall
-created new extension with default settings
-Checked and confirmed external FQDN resolves to correct IP address
- tested ticking/untick "PBX Delivers Audio, Supports re-invites, Support 'Replaces' header" under extension -> options ->Troubleshooting
- untick "Disallow use of extension outside the LAN (Remote extensions using Direct SIP or STUN will be blocked) "
- tick " Accept Push Notifications"
- Tried various combinations of SIP Transport and RTP Mode settings under Extension - >Phone Provisioning -> Network
Thanks for reading and any help would be high appreciated! Cheers
currently:
- 3CX Version, Enterprise Annual 16.0.655
- Server OS, Windows Server 2016 standard
- Server DNS: google DNS 8.8.8.8
- Is the 3CX Server Hosted and where? Hosted inhouse
- IP Phone Make/Model/Firmware: iphone 11 Pro,- IOS 14.01
- Provisioning Method: Local / VPN / STUN / SBC - local
- Trunk Provider or Gateway Make/Model - Breezeconnect
- Has the Firewall Checker passed: Yes all passed
- 3CX APP version on IOS: 16.1.5.43
