Solved ios/android phones not ringing
DaleSharp
Hello!
3cx was working perfectly for many years
then the last few months I have been having some issues with iPhone and android phones not ringing when called, so I decided to upgrade to V20
So I backed up old config, downloaded the ISO file from 3cx and installed
Restored backup
Everything working except for IOS/Android calls remains
O/S is Debian 10 3CX iso running under Proxmoxx
I have all the port forwards in place
confirmed IP is the same
I have followed the guides on 3cx website and others with Google Push, Power settings and notifications.
Reinstalled 3cx app and reprovisioned my oppo
All No luck
Just looking in the log before I noticed this
and hence my post here
Any help appreciated !
If you re-run the firewall checker, does it still pass?
Do you use IPv6?
If you turn on "keep active" in the Android 3CX app menu, do calls ring when the app is in the background?
Does this happen on both mobile data and WiFi?
@DaleSharp
Hi there.
Your Debian OS should have been upgraded to Debian 12, you will need to confirm and verify that.
Also, check your outbound traffic reaching the Apple server's IPs and there is no issue with your DNS too.
Reactions: Nathan@Voxtelesys
Do you use IPv6?
Firewall passes as OK
Not using IPv6
Same result on mobile data or wifi
Keep active yes and other settings that oppo require
It wont even ring when its open in the foreground
the only time the mobiles phone rings is whe it appears in the phones menu with the other IP phones
@DaleSharp
Hi there.
Hi Oleg.. thanks for the reply
The OS was upgraded to Debian 12 with the change to V20
DNS is using 8.8.8.8
No outbound firewalling
So only Android is working and only in the keeping active mode?
When calling iOS, do you get that error in the console?
Did you try to run the Wireshark and filter with DNS and apple IPs when placing the call to see if there is a reply from the apple server when the push is sent from the Phonesystem?
Hi Oleg,
Yes, Androids are only ringing with keep alive options
If I turn those options off the app receives no calls at all in the foreground or background
iOS wont ring in background
I'm not getting that IOS error in console when calling every time.. just randomly
However I am now getting the below when I call my android phone
I will have to install use iptraf or some other app as its a VM with no console and dump some data to see how its talking to apple servers.
new message after downing the ipv6 interface.
Yes.. and everything came good!
For others with the same problem you can turn off ipv6 in debian like this
edit /etc/sysctl.conf
add the following lines
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
Thanks for your help gents
Reactions: OlegR_3CX
Excellent and thank you for the feedback.
I will now close this thread.
BillyAkansel
