IP blacklisted
ethan.mcdonnell20
New User
I'm getting the error of An IP has been blacklisted but with no access to the management console on the hosted startup version I am unsure of how to fix it.
Any help is appreciated,
Ethan
I am sending you a PM can you check please.
You may also try to log in from a different public IP address making sure you use the correct credentials as provided via the welcome email received when setting up the start-up instance.
We had the same issue after upgrading the server. Old clients didn't work with newest server. After upgrading to newest client it was fixed.
Reactions: YiannisH_3CX
RJenkinsROCK
