iPhone App Speakerphone Option Not Displaying Correctly
qbitnetworking
This has been like this for a while but after switching to Speakerphone, this is the option I’m given when trying to switch back. I’ve tried uninstalling and reinstalling the app.IMG_4110.jpeg
Is known iOS problem, not app(s), started to occur with iOS14 - you could check the following way:
- while in a call, slide down the Control Center and tap the airplay button and you will see the same issue.
Usually a device restart solves the problem.
- slide down the Control center and tap the airplay button and you will see the same issue.
Do you mean it temporarily solves the issue?
I cannot give you a 100% sure answer - it happened to me also couple of times and I had a feeling it occurs after an iOS update; so if this is the case then yes, is temporarily.
Jeremy Hofex
