Solved Iphone iOS app SSL error.
Song
I have a custom hostname. 3cx.mydomain.com . and our SSL certificate is not valid. I was wondering if I can switch back to use the 3cx free one hostname.ca.3cx.us?. Please advise on how to change the hostname to the 3cx one.
Thank you
Are you in V18 or V20?
I'm on V18. I was able to fix it by the following:
  1. Create a backup of the system without licence and FQDN information
  2. Un-install the PBX.
  3. Access the customer portal and release the key from the current FQDN
  4. Re-install the system using the licence key and select the FQDN you'd like.
Reactions: Vali_3CX
That was the correct process and i'm glad you solved the issue.
tom.walker@blackcountryra
