- Joined
- Nov 2, 2026
- Messages
- 1
- Reaction score
- 0
Since last week or so, pretty much all our iPhones stopped getting push notifications, so they don't ring when someone calls. Android is fine. We've already lost several customer calls today.
The event log keeps showing this (Event 50020), for several extensions (15912, 15916, 15918):
"Failed to send APNS PUSH to device ... Internal exception occured: The SSL connection could not be established, see inner exception."
We're on a 3CX-hosted SMB instance (1454.3cx.cloud, v20.0.1765 SP10), so there's nothing we can check or change on the server ourselves.
I found an older thread with the exact same error where the fix was disabling IPv6 between the server and Apple:
I upgraded to v18 update 5 last night. Since then our users with the IOS app are no longer receiving phone calls through the app. When I look at the log, every time there is an incoming phone call, I see the following error:
Failed to send APNS PUSH to device iPhone11,8Tow’s iPhone(Ext.14). Internal exception occured: The SSL connection could not be established, see inner exception...
Could someone from 3CX take a look at our instance? Happy to send logs if needed.
Thanks a lot,
William
- 3CX Version: Enterprise Annual - 18.0 (Build 415)
- Server OS: Debian GNU/Linux 10
- Is the 3CX Server Hosted and where? AWS
- Has the Firewall Checker passed: YES
Thanks a lot,
William
