Solved IPTables not Found on Debian
dancestop
My network does not initialize because the IPTABLES are not found. I do not see the PBX on my router list. I am running the current debian and all maint was current the last I checked. See attached.
What hardware are you running this on
Intel hardware
It is MIXPC intel box
Are you running OpenBSD as the OS?
Sorry MITXPC Intel
Debian current with 3cX
Directory list
are the rco.d rc1.d , etc .. backups? is rc0.d the most current backup of rc.local?
I dont even know that rc.local is - how did you install Debian?
It was part of the 3cx package. See the first image that says IPTABLES not found. It references /etc/rc.local
I obviously have console access. How do I use the weekly 3cx backups to do a restore? Do I need to reinstall with the link above first?
If you are upgrading from a previous version of 3CX, IPTables will still be installed. But if you are installing a fresh copy of 3CX, it will use NFTables rather than IPTables.
I did : 1) download the current debian 2) I used RUFUS to move to USB 3) I used DEBIAN recovery 4) I restored with my weekly backup 5) I check maint and my IP addresses blocked 6) Everything connects now... no idea what happened
mazet
