Is it possible to display contact name in Windows App?
Guidm
Platinum Partner
Hello!
I want to change the display contact name and I'm doing some tests with the AttachCallData component. As I searched the forum, I found a post that performs this adjustment. LINK "https://www.3cx.com/community/threads/how-to-display-contact-name-from-mssql-database.82206/". However in the tests I verified that only in the windows App does not work. Is there any detail that needs to be adjusted?
NOTE: I tested it on other apps and it worked correctly.
Another doubt: Do you have any documentation of the variables that I can change in 3cx? If not, how can I see too many variables that can be changed?
There's no docs about those call data.
Also, the Windows app (older windows client) doesn't support that. Only the newer DesktopApp.
Reactions: edossantos
Right. How can I check 3cx variables that can be changed by this component?
There's no way beside knowing them.
The only two I know of are the displayname override, and the public_crm_contact which is a JSON of the CRM match.
NetworkActive
