Is it possible to use one Google SSO token for multiple independent 3CX instances simultaneously?
muc
Good day everyone,
I’m currently setting up Google SSO for several independent 3CX systems, each hosted under its own FQDN.
My question:
Is it possible to use a single Google OAuth client (token) to authenticate users across multiple 3CX instances simultaneously or does each instance require its own dedicated Google OAuth configuration?
Thanks in advance for your help and input!
Each pbx need his own configuration.
Hey there,
I know that each PBX can only have one Google SSO integration and that it’s not possible to configure multiple within a single PBX.
However, my question is a bit different: would it be possible for several different PBXs to use the same Google SSO token?
For example, if I have three separate systems (3CXs), could they all use the same Google SSO integration/token for authentication?
Hey there,
No because redirect URL is different on each system. You must create 3 projects in your cloud console.
Kayla Norris
