+ is not working on outgoing rules
Bilalikram
Forum User
Deaf all
I have an issue with ongoing rules, + is not recognising in outbound rule.
For locally calls dailing with + not working, which is important as everyone saves phone directory with + ,
Thank you
Could you check the following?
Access the Management Console and go to "Settings >> E164 Processing", if it is enabled, disable it completely and then try again.
Let me know how it goes.
Working fine thank you for support
Dear Chris,
I have disabled E164, it works with local calls, but the same problem happen for the international calls now.
When I enable E164 only local call issue , can not call with + , when disable
It works for local callawhen I disable E164, but it's not working than for international.
Could you please advise how could I make both works with darling + , Thank u
What are you dialing to make international calls?
Could you provide an example of what format the number you dial is in?
Also, could you attach a screenshot of your Outbound Rules?
RemyDijke
