Is openwrt an OS compatible for 3CX installation?
Stringmusic
I've been reading about 3CX and the typical installations that have documentation for specific OS. As of now, Rasbian, Debian and Windows are the OS on the servers or devices that can host 3CX.
My question was: Has anyone tried to install and run 3CX on openWRT or a device that supports it?
There is some discussion about OpenWRT in the forums but it's specific to other Voip instalations.
Any successses or chanlenges with openWRT and 3CX?
Thanks,
Openwrt is not a supported operating system , I very much doubt you could install 3cx on it
to be supported, stick to the supported operating system
Dont go there...
Reactions: Stringmusic
Unfortunately the OS you mentioned is is not supported.
The only versions of Linux we support are:
1.) The version of Debian we provide with our ISO.
2.) The latest Pi OS Lite which was released as Debian 10 Buster (linked in our guide here)
Any other Linux OS should not be considered supported, and we expect that your installation will be unstable and face issues due to reasons that are too numerous to go into right now.
No worries,
Thanks for the commentary. I was just wondering, because Raspberry Pis with the right components are on back order in some locations.
thanks,
neshima
