Is panasonic KX-TGP600 supported by 3CX
AEGIS_SEC_SOL
I don't see the Panasonic KX-TGP600 in the compatible phone/adapter list. Is there a way to make this work on 3CX?
yes, its compatible but you have to configue it manually, no provisionning
Reactions: nub
All SIP devices should work with 3CX, but of course if they are not supported then you have no automatism to set them on 3CX and no compatibility tests done from 3CX, plus if you encountered a problem you are on your own and probably without fix.
3K8iMGWviZ
