Is the Raspberry Pi 4 compatible for SBC?
NetcommMike
We are looking at sending some phones home with some of our employees and have been looking at setting up Raspberry Pi devices for SBC instead of trying to get home routers/modem-all-in-ones configured for Direct STUN. All the documentation says to use the 3B+ boards, but I found that the Raspberry 4 boards are available. Will the Raspberry Pi 4 boards work with the SBC? I feel like this is a little bit of a dumb question but just wanted to make sure before we spend any money. Thanks in advance!
To answer your question - 3CX answer is no but some people may have gotten it to work which will not be supported by 3CX
If one phone at the employee home, you may get away without any firewall changes. We have clients with one phone and it works OK.
Another option, is the 3CX windows application or 3CX web client
Hi Mike,
Only Raspberry Pi 3B+ is currently supported at the moment
I am glad that I asked! Thanks for the quick responses. I appreciate it!
[email protected].
