Is there a way to change System Extension Numbers?
jim@valley-tel
Gold Partner
We have a client that is using the 700's for extensions. They want to use 777 as an extension. It is currently used for PIN protect IVR. I do not see a way to change the PIN protect number to something other than 777.
Thank you 3CX community!
Hi Jim,
I think that you can change this value in Admin --> Advanced --> Parameters and then look for 777 in the custom parameters.
regards,
Joel.
777 is hard coded to the PIN protect IVR and cannot be changed.
Reactions: NicholasP_3CX
x1515
