is there a way to disable muting ring tones?
ervinkasaj
Forum User
Hello all!
I want to disable the option to mute ring tone for some users. Or maybe just ignore the mute and ring anyway.
Is it possible?
Hello all!
Is it possible?
Are you talking about deskphones?
Yes.
We use Fanvil X3S desk phones
Yes.
You would need to use a custom template with a parameter that blocks the volume button, if there's one on Fanvil (I think there is).
Then use that template for your phones. You can copy the official one and edit that.
Thanks. Will try and get back with results
hughesdouglas
