Is there a way to flip calls between the 3CX app on the phone and on Windows?
checkinyyz
Often I will answer a call on the 3CX softphone on my phone when I'm away from my desk but then I'll want to switch it to my computer when I get back to it since I have a better USB headset there and vice versa. Is there any way to do this as the 3CX app on Windows doesn't seem to know there's any call in progress at all. I guess I could park the call and pick it up but then the person I'm speaking with would know I did that. Just wondering if there's a cleaner way to do this.
Hello @checkinyyz
Unfortunately there is no way to do this without the caller being aware of the transition. The best to way is what you suggested, park the call and retrieve it from the second device.
You could also blind transfer the call to your extension but the caller will also be able to hear the transition.
