Issue Adding Certain IP Addresses to the Blacklist
samehJABRI
When I added an IP address to the blacklist starting with 1xx or 2xx, it was successfully added to the blocked list. However, when I added an address starting with 69x or 89x, it told me that the address already exists. But when I checked the blacklist, this address was not visible in the list of blacklisted addresses.
Best regards
Its already on the 3cx blacklist so you dont need to block this ip.
I want to see it on the list blacklist
You cant
Why can't I see it in the list?
The 3CX provided IP-Blacklist is both big and dynamic.
Showing it would fill several pages, not letting you easily manage your own Black & White listings.
Is it possible to access it via SSH? Or WinSCP?
Who is on my block list but doesn't appear in my blocked list?
This is a massive blocklist managed by 3cx. Doenst make any sence to check this list because you cant change anything in there.
Reactions: paulodagraca
The global block list is IPs that 3CX is blocking worldwide. So presumably multiple attacks on multiple servers.
tom.walker@blackcountryra
