Issue on Trunk not registering anymore - where to find logs?
msavazzi
I have moved to 3CX 2.0 and I'm not able to find any usefull logs to diagnose why it is not registering anymore.
I've raised the Logging Level to Verbose.
But I if edit the trunk, ask to re register or anything I'm not able to find anything in the logs :(
What am I doing wrong?
3CX : Version 20.0 Update 0 (Build 1340)
Running on a Virtual machine
Nothing changed on the network on my side and should not have changed on the telco
Generating a supportinfo file will give you the logs.
you could alternatively run a wireshark on the machine but you'd have to install it
Code:
sudo su
apt-get update
apt-get install tshark
mkdir /home/wireshark
tshark -i any -b filesize:10240 -b files:20 -w /home/wireshark/mine.pcap
or ask your SIP provider for more logs.
Reactions: SweetAction
Senergia
