Issue with editing extensions
novatel
i receive Internal server error, when trying to edit an extension:
"An error occurred during the activation of a particular registration. See the inner exception for details. Registration: Activator = Editor (ReflectionActivator), Services = [ManagementConsoleJS.Services.Abstract.IEditor"
3CX Version number 16.0.0
Any help?
Clearing the cash did not help, another browser as well.
I use V6 on my NFR license.
Hello @novatel
Is that the entire error you are getting? Are you getting the error on a specific extension or all of them? Do you have phones provisioned under the extensions that face the issue?
Hello Yiannis,
i found out that i can delete, but can't edit any old extension. I successfully tried to create a new one and managed to edit it. It seems that issue appeared after my tests with Office 365.
Can be the problem related to O365 integration?
Are the affected extensions, extensions that were imported from O365 or did you restore a backup from a previous version?
All extensions are affected- those that have been imported from O365 and extensions, created before O365 integration.
Please check your Inbox as i have sent you a p.m. with what we will need to further look into the issue.
BIT Incorporated
