Solved Issue with Fanvil V62 as SBC
voipdevice
Platinum Partner
In one location, we have a Cyta router HG8245X6-10, a 3CX SBC (Windows), and a Yealink phone. It works without any problems, but we need to replace the SBC with a Fanvil V62.
The phone was configured using auto-provisioning, but it cannot establish the tunnel. How can I check where the issue is located?
You would want to up your logging on the admin console and then check logs to see if its hitting you.
check blacklisted IP, start a trace on the fanvil and check the capture.
Resetting the phone and reconfiguring it in the target network helped solve the issue. Previously, it was configured in another network, and the SIP proxy field was blank.
Reactions: NicholasP_3CX
VOIPEric
